Custom made volkswagon powered 8x8 with sea doo pump
Welcome to 6x6 World.
Nissan 300 zx motor is 165 hp 15" tracks x10' long is 3600 sq inches on the ground that's .66 lbs per sq inch at a 2400 lb vehicle should work pretty good.
I think you are on to something Chris. A suspension would add a lot to making these things more usable. Eliminate the wheels and tires and replace with tracks (that never de-bead, lose air, etc) and eliminate all the other chains and misc. items you mentioned and you will be an innovator in this field.
In fact, I picked up Brushcutter's Cushman Marsh model Trackster. It's hydraulic, tracked without tires, and has a leaf suspension. I am very impressed with this thing and it is smoother than any other amphibious atv I have experienced.
I would post some pics of the engine in and the headers I hand fabricated but cant remember how to post them. The jeep rear end was a drum brake setup so i changed it to discs and fabricated a drum to mount the plastic 1 inch thick sprockets' on that drive the tracks. I still have to mount the radiator but the two electric fans are on it. So far I have fabricated one of the shoes that roll on the track, Its the one in the front leading arm suspension.
Oh I forgot I spend a lot of time riding my Razor 1000 and quad and keeping them up also and have bought a tig welder and aluminum spool gun to help with this work.
