Ok, I don't yet have a max, but am really interested in the track assemblies. There are bearing extenders? Are the axles longer as well? It looks like the wheels are further out from the body.
Still working on a max.
Thanks
Stephen
Thanks
Stephen
There are bearing cages that use an extra bearing on each axle and there are also hub adapters that move the wheels farther away from the body. You can only use 21x11x8" tires with the tracks. As far as putting them on, Im not 100% sure.
Thanks, that is what I was really asking. The bearing supports move a bearing out further, probably just about the same as the spacer does. Now it makes sense.
Stephen
