Installing Tracks
Results 1 to 8 of 8
Thread: Installing Tracks
    Feb 2015
    Haliburton ON
    74
    Installing Tracks
    After years of struggle I have found an easy way of putting on my tracks for the winter. I used a strap with a ratchet buckle like truckers use to tie down their load. The one I bought has a ratchet permanently attached to one end and you thread the loose end into the ratchet and tighten it down. The tie down compresses the track so you can easily insert the rod that connects the ends of the track.
    Here is the process:
    1. Lay the strap on the ground
    2. Lay the track on top of the strap leaving the ratchet just past the end of the track.
    3. Let all the air out of the rear tire.
    4. Back the Argo onto the track starting at the end opposite the buckle and stopping just as the end of the track comes out from under the front tire.
    5. Bring the other end of the track and the strap with buckle up and over the tires to the front.
    6. Make sure the strap is centered on the track and straight
    7. Insert the loose end of the strap into the ratchet and tighten it up until the holes in ends of the track align and you can insert the rod.
    8. Insert the washer and cotter pin on the rod, re-inflate the back tire, undo the ratchet and drive off. You are done!
    May 2017
    AK
    27
    If you bolt a D-ring to the ice claws closest to the splice , a total of 4 you can use 2 shorter ratchet straps .
    Once you get the track rolled over like you said you hook the 2 ratchet straps to the D-rings .
    Ratchet them snug and close the ratchet , drive the track forward a complete revolution , tighten the ratchets .
    You may have to do this a couple of times forward and back . A little bit of practice and it should only take a couple of revolutions .
    I have track windows in my track so for me I took and opened the hooks up a little more on the straps .
    Just another options , seen a guy do it your way and he was a master at it
    2,637
    a bob , i like that procedure cause your compressing both the front and rear tires directly with the strap ... thanks , i'm going to try it . j.b.
    Feb 2015
    Haliburton ON
    74
    I am curious Hawkster. Why do you need to drive forward and back?
    Feb 2015
    Haliburton ON
    74
    Good luck JB
    Aug 2009
    Pincher Creek, Alberta
    266
    That is pretty much how I've always done mine, except I have always dropped the air out of all the tires. The front and rear ones definitely get squashed with the strap. I'll have to try it with only deflating the rear tire.
    May 2017
    AK
    27
    Sorry I didn't reply sooner . Depending on the condition you could put the tracks on without deflating the tires , like say out in the field . Driving it back and forth let's the ratchet straps pull it together easier without getting Western with them . It helps the ends walk together .
    Feb 2015
    Haliburton ON
    74
    Quote Originally Posted by Hawkster View Post
    Thanks Hawkster. Now I get it.
Tags for this Thread
