JLO L395
Results 1 to 4 of 4
Thread: JLO L395
    Jan 2010
    Omaha NE.
    18
    JLO L395
    This is my first post here so I hope I get it right. I bought a terra tiger here in NE. I thought it had a 295 jlo, but it looks like a 395. I got it to fire alittle today. The problem is I am not sure if the gas line is hooked up right. The card is a tillotsen HD36A. There are 3 outlets on this carb and I need to know if I have them hooked up right. From the front looking into the carb there is one on the bottom of the pump section, one on the right side on the third upper section of the pump section, and one on the carb body on the left side. Is this the gas line fitting? Witch one goes to the crankcase for the vacuum pump,and were does the last fitting go? Thanks for any help.
    Sep 2008
    woodland pa
    534
    pics helpful
    some closeups someone will chime in/ post pics of engine carb
    Aug 2007
    near olean, ny
    1,083
    Smile tillitsons
    the bottom is fuel in... the side higher is vacumme from the block behind the carb. the third higher is fuel over flow,return to tank line....
    Jan 2010
    Omaha NE.
    18
    Tillotsen
    Quote Originally Posted by Amphiman1 View Post
    Thanks, that would explain why I had gas running all over. That was the way I got and I didnt think it was right. I will try the new setup tomorrow and let you know.
