what belt do i need for a 95 max II with a 18 horse briggs and stratton vanguard? i need a model number or a name and model number
1 800 255 2511 rec has then press 4 and jay will get it . robbie
haha ok thank you yeh i called them i was just seeing if there was a belt i could get in town cuz i need one for this weekend
Recreatives #15252AA belt is 44 and 3/4 Inches X 1 and 3/16 inch wide I havent found an exact replacement good luck.
The spare that came with my Max II was numbered 15252AA as well.It was 1 3/16" wide all right but was less than 44" long.The one running on it was of a different number but was exactly 45 5/8" long and was a bit narrowed but not worn out.The 15252AA was too tight at minimum adjustment.Put it in gear and away you went with no throttle.I replaced with a Dayco HP 3003 which is 44 7/8" long and 1 3/16" wide but even at minimum adjustment it was a workable improvement over the 15252AA belt but still is too tight,shifts desperately hard etc.,creeps in gear . That 15252AA number is not a Dayco or Carisle number but is made by one or the other of them,it must be a custom RI number after manufacture.I have long abandoned any hope of getting a perfect fit belt and though advised to contact RI,it was RI who sent the 15252AA belt which wasn't even close to long enough.
