Hello everyone , im James and I just purchased a 1999 Max Iv
I am in need of a few parts and was wondering if anyone could help me out on where to purchase these things. I have found richards reclics, and Recreatives. I bought this 6x6 with intentions of reparing it and selling it, but im considering keeping it, so I truely want things fixed right. It was purchased new by my neighbor in 99 and sat with a tarp over it since 2002. Once I cleaned the piles of pine needles from it and gave it an inspection, it needs all new chains, 2 tensions sprockets, and 1 outer wheel bearing. The Problem I am having, is the side that needs the wheel bearings, had a little water in there and rusted the axle, sprockets and do not want to come off, I've already drilled the rusted set screws out, but no luck. So my worse case, is that I just cut the axle off and replace it all. The other 11 bearings seem to be nice and tight. 18hp Vanguard fired up with no problems, and trans appears to shift. The body is in excellent conditon, and also came with a roll cage. 21 in tires. If anyone has any of the parts im looking for please contact me at chevyguy7144@aol.com or on here, as i will check often. Thanks
