I have seen people put 63 mm brgs where 62mm brg should be , it is so little that you can not even hardly notice , but when the loc collar is tightened up it breaks the inner race just like what happened to you, double check your brg size is correct for that model unit
the new brg should have been somewhat difficult to slide on the shaft, usually i have to emery cloth the shafts perfectly clean to get the fresh brg on, if it went on without having to clean the shaft perfectly, it's probably the wrong brg
He who has not cruised the back country in a 6x6 , has not lived life to it's fullest
A Mans level of mechanical education directly corresponds to the level pain suffered while getting it
