Hello,
I just got my first AATV, it's a Max II, but I'm not sure what year it is. I bought it for $400 and was a little unsure of how it was going to run and how much it was going to cost to get it going. I put a bolt in the middle axle where the shear pin came out, put a battery in it, and took it out to see how it was running. I had a blast driving it around, and it ran great for about 1 1/2 hours until the belt broke. When I went to take the clutch off to clean it out I realized that the engine was not bolted down, it was just sitting on the mounts with bolts put through to keep it from sliding, but not bolted down, so that is the next thing I need to work on to get it running again. I have the replacement belt I got from a Max dealer up here, and I can't wait to get it out again and see what it can do. The only problem I had while I was using it was that it would pull to the right, and it was difficult to make left turns. I did find that one of my left tires had lower air pressure but I don't know if that would affect it enough to not want to turn. Does anyone know what else could cause that other than a low tire? I also checked the chain tensions for the front and they are about the same so I don't think that is it. Also, I noticed that my back tires spin more than the other ones, is this normal or are all tires supposed to move at the same speed? Please let me know if you have any info that could help me out and get a good start on making this an awesome machine again.
