Do I need to remove track axle extenders to get the bearings?
Results 1 to 8 of 8
Thread: Do I need to remove track axle extenders to get the bearings?
    I'm in the process of getting at the center axle sprocket that has half the teeth missing and went to go remove the axle but I have tracks with the axle extenders, do I need to remove all the wheels on that side and remove the extender so I can get at the bearings?
    Thanks!
    -Jedon
    I edited my original response because I gave you wrong information and don't want to mislead anyone else. Sorry, see Eldon's post below.
    Mar 2008
    New Brunswick,Canada
    461
    I think he will have to remove all the wheels on that side because the rail is bolted on the outside of all three cages.
    Quote Originally Posted by Eldon View Post
    Gotcha. When you do that, I guess you can just leave the tracks on the tires?
    Mar 2008
    461
    You might be able to if you deflated the tires completely.Otherwise there would be too much pressure on the wheel studs and if you could get them off, you would never get them on.Tracks are a lot of fun but only when using them, for maintenance they are a real liability.
    Thanks all, I decided right away that I needed to just go for it so did, I took the valve stems out of all the tires on that side, removed the middle wheel, then removed both the other wheels and the tracks as a unit but am sure I will need to do the standard track install when putting it back together.
    Now I have a new problem, how in the world to get the jack shaft out. I have all the adjusting plates fully unbolted and the cotter pins out but can't figure out how to get the whole unit out of my way. I really just need it gone so I can replace the center axle sprockets. This is complected by the axle extenders, the how to write up doesn't mention the added pieces of the tread kit.
    You don't have to remove the jackshafts to remove the sprocket and axle below them. Since you have them loose, that will give you enough room to move them around and get to the bolt that holds the sprocket on. You should also be able to get to the locking collar with a long punch. I have used an 18" crow bar in the past with a pointed end to rotate the locking collar on the middle axles.
    Mar 2008
    461
    I'm all eyes and ears regarding bearings,jackshafts etc.Just got mine on jackstands,opened up etc.Mike when I removed the brake calipers it was so easy I was embarassed that I had asked.
    The mechanics of bearing change looks straightforward,I feel I will be pretty good at it on the sixth axle.LOL.The biggest challenge I see at this stage will be removing the allen screws setting the collars to the solid axles as I have read they use locktite.
