Hi everyone, 1st post on this forum.
I recently acquired a 2000 Max IV in excellent, little used condition (to be honest...on a whim).
I have recently baselined the vehicle to initial factory specs: changed all filters and fluids, new plugs, installed an upgraded battery, washed the inside of the tub, greased the fittings, lubed the cables, adjusted the chains, and checked axle bearings for freeplay after lifting the vehicle off the ground. The Max came with the heated cable option, a 2500lb. Warn winch, and 22 inch tires (very good condition). Since this is my first 6X6 ATV, I would like to get some advise from some of the more experienced tuners on the forum.
I am considering some upgrades and improvements to build some additional reliability, safety, and overall usefulness of this vehicle.
The factory axles and bearings look to be in good shape with nominal free play. I noticed that the 2010 Max units have heavy duty bearing blocks (and I am assuming beefier axles than on my particular vehicle with it's stamped steel bearing plates. Should I consider an upgrade to a beefier kit now (along with solid heavier axles) or should I wait till they show signs of wear and play? Do extended axles add additional stability to the vehicle (as well as clearance for tracks) at the cost of handling/turning or other negatives (extra water thrown up when in a lake)?
I live on a 225 acre deepwater lake. I have boats but would like to take a Max out if it is a reasonable proposition on a mile long lake.
Has anyone used this type of vehicle in an open water environment where it may be exposed to other boat wakes or wind? Do the factory tires offer sufficient floatation to keep the vehicle from sinking should the hull be fully swamped (don't want the expense of a diver recovery team). Will bigger tires/rims offer that extra safety/flotation margin? I was even thinking of getting some spray marine foam into the hull but I am concerned that the chain lube and maintenance will be more onerous in the future should the grease and fluids need attention.
BTW, the forward and rear Zerk fittings are a bear to reach. Anyone install 45 degree Zerk fittings or use some kind of grease adapter to reach them easily?
In some of the member videos it appears that the Maxes are somewhat nose-heavy in the water. I noticed a video of a pontoon retrofit, but it looked like the rear of the pontoons weren't even in the water while running.
I am willing to add some marine upgrades (bilge pump, trolling motor, etc.) but I don't want to consider it if it will be a dicey proposition in choppy water.
I would also consider taking it out on the lake when it is frozen as long as I know that I can sink-proof it, should the ice give way.
Any other recommended upgrades I should consider?
Thank you in advance for any help.
Any advise is welcome!
