What is a GOOD Winch to purchase for use on a MAX II
Results 1 to 7 of 7
Thread: What is a GOOD Winch to purchase for use on a MAX II
    I have a Superwinch T1500 on my Max II which recently stopped working, it will go only one direction. I tryed opening up the solenoid testing the wores reversing them etc..
    I have a feeling there was a different issue involved because this winch broke the 1st time i tryed to use it. ,I was stuck in the snow & tryed to pull the MAX out of the snow (while hitting the switch next to the MAX i was not in the MAX so that the weight would be less).. The winch strained & failed to pull the MAX beyond a few feet & just stopped.. The Winch has had to have been "tired" & this was the last straw i feel..
    What im looking for is a winch where i will not have to upgrade the gauge of wiring (which is standard for a MAX winch i believe).. I am looking for a little overkill in regards to power, a winch that can pull a MAX out of deep mud with me sitting in it! (im 220lbs). A remote control feature would also be a plus!!..
    Let the suggestions fly! what do 6x6'ers suggest for a Winch replacement & where can i get one??
    THANKS!!
    Mar 2008
    New Brunswick,Canada
    461
    The Max II comes now from the factory with a Warn 2500 lb pull and my '03 came with a 2000 lb.
    Mine has always got me out but a 2500 lb one would be better. Max has for a long time used Warn and Argo I believe has switched from Superwinch to Warn.It's hard to beat a Warn but they are a bit pricy.
    Nov 2009
    2,910
    The bigger the winch, the faster it will suck your battery dry. Even when not under load larger winches draw more. MaxII's have a tiny battery from the factory, you might consider putting in a larger one.
    Nov 2010
    West Bloomfield, MI
    44
    I have installed several Viper Elite winch kits on various ATVs and my Max IV. Their winches are totally waterproof, come with a complete kit including a winch cover and cabling, and include a wireless remote control (as well as a hard wired switch) and synthetic cable. They also use the same bolt pattern as a Warn Winch so they are generally interchangeable. I originally found them on an Ebay store but I believe that Moto Alliance has their own site as well. A very good product overall. I do believe they have three different versions with the Elite being their top of the line kit.
    https://motoalliance.com/Site.do
    Nov 2008
    apex, NC
    263
    I have both a viper 3000lb and a warn rt25. I like the warn a lot better, it's smaller, seems stronger, adn is much more waterproof. the viper got clogged up with mud and I had to rebuild it.
    Thanks for the suggestions, I look at those winches but boy are they pricey!
    Im looking to spend like $200 tops, & prob have to order online casue no stores stock these things by me..
    What do you think about this one: Sears: Online department store featuring appliances, tools, fitness equipment and more
    Any input? it looks decent
    Mar 2010
    Oconee County, SC
    823
    I have a Champion 2000lb ATV Winch on my Hustler 950, Raceone3 uses the same winch on his machines. I got pulled out allot this past April Busco and I used it to pull out a few other machines too. All hooked winch to winch and no problems getting unstuck. For under $100, you cannot go wrong.Champion Power Equipment - C20051 You should be able to find these just about anywhere.. Auto Zone, Pepboys, O'Rieley, Tractor Supply, EBay, and the list goes on and on.. Amazon too.. Amazon.com: Champion ATV Winch: Home Improvement
