Couldn't move it so onto the drilling.
Hex key doesn't seem to want to be centre punched or drilled does it.
Apart from the little shard I was trying to grab the sheared tip doesn't protrude from the grubscrew which is recessed into the sprocket tube about 2mm.
I have ground with the dremel so there is an even dish in the top of the hex key tip and can't get good adhesion with glue or magnet to pull it out.
I would love to drill out the 5/32" of high tensile steel currently loitering in the grubscrew, what drill alloy does this effectively?
