Originally Posted by
jstout9
I'm hoping new shifters and an adjustment of the bands will do the trick.
By the way the only thing I did to the t-20 was check and add fluid to it. It only took an ounce or two.
If it was stearing ok leave the band adjustment alone for now. They have nothing to do with shifting from forward to neutral, to reverse. Even when shifting by hand a little rocking helps. It should not be a hard shift in. If it is hard, rock it untill its easy and it will just slip into place. If you force the shift, you can grind and mushroom gears in the t-20.
