Max II Belt Issue
Results 1 to 2 of 2
Thread: Max II Belt Issue
    Oct 2011
    Ohio
    7
    Max II Belt Issue
    I'm fairly new to the 6x6 world or aatvs, but have a solid understanding of mechanics. I have a late 90s model and the belt slips at times. It has an 18hp Vanguard. It drives just fine without slipping unless i come to a good size hill without speed. Watching videos on youtube, my machine should be able to climb the hills. Basically what I need to know is what is the width of a new belt? I know I should probably just get a new belt but Im just curious. Looking at the Larger clutch the belt at idle doesnt touch both sides of the clutch. There is a good 1/2inch gap from the belt to the other side of the clutch. Is this normal? I can upload pictures if necessary.
    I believe the belt should be 1-3/16" wide. The belt should touch both sides of the driven clutch. Upload some pictures if you have them so we can make sure we are talking about the same thing.
Tags for this Thread
