I've got a 94 MaxII I have been rebuilding as it sat for quite a bit with water in the tub. Fashioned myself some new chain tensioners and got me some new chains. I cleaned up the t20 got all the fluid changed and added the Lucas anti slip.
Was hand cranking the T-20 to make sure the shifters were correctly engaging when I noticed what appears to be a crack in the rith side output sprocket that runs from the bottom of one of the sprockey valleys straight through to the output shaft.
I did a search and wasn't able to find any reference to such a thing being purposely cut into the sprocket (It looks like it is almost that way from the factory but doesn't make any sense?). Why would this thing crack at this point? If it is supposed to be there what actually keeps the sprocket from stripping the shaft or vice versa.
I tried to get some pictures uploaded but having trouble with the card reader. Can anyone tell me if this is normal? If not can anyone give me the specs for the sprocket as I can pick one up locally from Motion Industries as they are close to where I work.
Lastly, IF this thing is bad and I do source another is there anything preventing me from pressing on the new one but leaving the T-20 complete and NOT doing any damage or do I have to tear apart the whole darn thing just to press on the new sprocket? Thanks for the help.
