New Max IV owner saying hello
Results 1 to 2 of 2
Thread: New Max IV owner saying hello
    Oct 2011
    Duluth MN
    19
    Just joined forum and have already found all the information i was looking for. I just bought a 96 Max IV with Command 20 Kohler and 26" Terra Grips. It came with the factory plow and winch setup and the roll cage. It had issues when I bought it so the price was good. Got most everything squared away now and ready for some fun. I adjusted the static covernor position and got the motor to idle down good. Sorted out all the wiring issues it had going on, so everything functions like is is supposed too. Changed oil and transmission fluid and adjusted chains. Still need to get a new non leaking gas cap and a headlight trim ring. This forum has been a great resource for all the questions I had about this machine. I am planning to use it to plow this winter and was wondering if anyone can tell me how well I can expect it to push snow. Also have been reading about condensation in heating throttle cable tubing, mine is still almost full of water, and wondering if anyone has yet to find a permanent solution to this issue. Just posting the first time and had a few questions and introducing myself.
    Aug 2011
    Central Ohio
    100
    Welcome! My Max IV does much better pushing snow with the tracks on than without, although even just with the tires alone, it does allot better than a quad. Your biggest problem without tracks will be getting high-centered in deep snow when you try to make your first cut.
    I haven't run into the condensation problem with the heated cable yet. Wonder what the effects of antifreeze in the plastic tubing would be instead of using electric?
