Sound off with your Max type, Serial #, and Year
Page 37 of 43 FirstFirst ... 27 35 36 37 38 39 ... LastLast
Results 361 to 370 of 421
Thread: Sound off with your Max type, Serial #, and Year
  1. #361
    Jan 2019
    Eldridge, IA
    8
    Just bought my first 6 wheeler. Max II - 1994, SN 10635.
    It’s in really nice shape, but I don’t know much about them. Runs and idles fine, just not sure proper shift sequence. If lever is in neutral, do you just depress foot pedal brake to shift in forward or reverse or do you need to pull back steering levers as well? I haven’t had a chance to really try it yet, just don’t want to grind gears.
    Thanks!
  2. #362
    Apr 2016
    VT
    266
    When ever shifting, make sure that your hand is not on the throttle, even a little bit.
    When the gear lever is in NEUTRAL, you have to pull all the way back on both levers, to allow you to push/drop gear selector from NEUTRAL to FORWARD.
    When shifting from NEUTRAL to REVERSE, you need to make sure that the levers are both all the way forward.
    The "parking brake" pedal has nothing to do with shifting, but it may be wise to have it set in "park" as a safety precaution.
    Be advised, that due to the nature of the T-20 transmission, you might need to "coax" it into gear. Some do the "rock from side to side" thing, but I let the levers go again and then pull them back slowly again....when in neutral, the gears are turning and when you pull back slowly on the levers, you are engaging the brakes, which will slow the gears down and that often is just enough to let the gears align and slide into place.
  3. #363
    Jan 2019
    Eldridge, IA
    8
    Thanks for the info. I did download the manual so I got some good info from there as well. I'm going to try it out tomorrow when I'm back home.
    I also noticed my belt is the incorrect length. It's actually longer, yet still wants to creep forward when in gear, so I'll need to research belt removal, adjustment, etc. I'm hoping my clutches are still good and don't need rebuilt or worse yet new ones.
  4. #364
    Feb 2018
    Cape Coral FL
    17
    Max VI #5517 what year please?
  5. #365
    Apr 2016
    VT
    266
    Approx 1978
  6. #366
    Mar 2011
    Colonial Heights, VA
    497
    Serial Number Year Model Username
    0552 1970 Max II Waud
    2101 1970 Max II Brunpup
    2732 1971 Max II Rempie
    2966 1971 Max II Swfleur Kawasaki 440a stock upgraded to a 4-stroke
    3095 1971 Max II Kunzmm137
    3164 1972 Max II Whitefisher
    4238 1974 Max II Jasonku
    4270 1974 Max II Msafi65
    4382 1974 Max II Dano1877
    4729 1975 Max II Radioactiveboyscout
    4976 1975 Max II Dw89xj JLO 440
    4984 1976 Max II Rsashurn
    5036 1976 Max II MikeAB1
    5398 1980 Max II Dano1877
    5825 1980 Max II Ygmir
    5949 1980 Max II Dano1877
    6001 1980 Max II Yogi1644
    6152 1980 Max II Moonball1466
    6352 1980 Max II Tattooman
    6479 1980 Max II BRB
    6677 1980 Max II Cementhead
    6864 1980 Max II Dave Smith
    7043 1982 Max II Special Ed 16 HP Tecumseh
    7127 1983 Max II Mad-max
    7337 1984 Max II Thenry OH160 Tecumseh
    7??? 1983 Max II Applejack
    7400 1985 Max II Adondo
    7460 1985 Max II Cannibal
    7462 1985 Max II Drewstang
    7664 1986 Max II Gravel128
    7718 1986 Max II Wnc 6x6
    7751 1986 Max II Msommer
    7837 1987 Max II Chiefdiesel Big Max
    8270 1989 Max II Duncan
    8323 1989 Max II Swfleur factory Tecumseh OH180
    8491 1989 Max II River2406
    8985 1990 Max II Coosaridgerider
    9068 1990 Max II Drykilned Vanguard 16HP
    9344 1992 Max II DZG
    9459 1992 Max II Rottsrool
    9668 1992 Max II M38inmaine
    9699 1992 Max II Divedigger
    9710 1992 Max II Iwantonetoo
    10055 1993 Max II Snake stomper
    10175 1993 Max II Tdog50
    10216 1993 Max II Tattooman
    10353 1993 Max II Mhinton5868
    10493 1993 Max II JPSwift1
    10608 1993 Max II Gilby
    10635 1994 Max II Tman52748
    11011 1994 Max II Carbonfast59 16HP B/S Vangaurd
    11100 1994 Max II Nivek
    11212 1994 Max II Warpony1
    11588 1995 Max II Normable
    12539 1996 Max II Drive2 500T
    12846 1996 Max II Hipowerone 14 HP Vanguard
    13270 1996 Max II JPSwift1
    13594 1997 Max II Outlaw1
    14338 1997 Max II 67Datroad
    14165 1997 Max II Teddotson 23hp Predator
    14177 1998 Max II Outdoorsy74
    14951 1998 Max II Newargoowner
    15072 1998 Max II LW1911
    15306 1999 Max II Johnnova
    15327 1999 Max II JPSwift1
    15646 1999 Max II Aetractor
    157XX 1999 Max II Monoped
    15817 1999 Max II Special Ed
    16063 1999 Max II Johnt
    16436 1999 Max II Hoytme 14 HP Vanguard
    16463 2000 Max II Johnboy VA
    17??? 2000 Max II (SS) Model Citizen
    17097 2000 Max II Wilkie
    17116 2000 Max II Garretttpe
    17335 2000 Max II MaxII420
    17537 2000 Max II Wiggy 18 HP B&S
    17545 2000 Max II Tplayer49
    17636 2001 Max II Jonjon6x6
    17716 2001 Max II Wiggy 18 HP B&S
    17752 2001 Max II Bigfoot Thebuggyman1
    18083 2001 Max II Savage 40
    18564 2002 Max II CBass Current 18 HP Block bore out like a Bando
    18842 2003 Max II Eldon
    19002 2003 Max II Gambler
    19134 2004 Max II Carbidegrinder
    19794 2006 Max II Johnnova
    20126 2010 Max II 9Toe
    21439 2013 Max II RI/Mudd-Ox [Last NY built]
    21572 2015 Max II Jim Fitch 29 Kohler Command
    5517 1978 Max IV Yeral
    6274 1979 Max IV Madmax4 16 HP Vanguard
    6278 1979 Max IV Crashingone2002
    6381 1980 Max IV Wildcard
    6960 1980 Max IV Frankqpardoins Kawai 440 two Stroke
    7329 1984 Max IV Fishfreak11
    7458 1984 Max IV Teddotson 440 Kawasaki
    7506 1985 Max IV Izme39
    7681 1986 Max IV Toys4Me
    8036 1988 Max IV Maxoverdrive
    7975 1988 Max IV Lazy Hiker
    9212 1991 Max IV Anotheramature
    9298 1991 Max IV Green 20 HP Kohler Magnum
    9575 1992 Max IV PAMike
    10161 1993 Max IV Jnrmoto
    10164 1993 Max IV North Country Tough
    10375 1993 Max IV Rickemd1
    10410 1994 Max IV Blown84gt
    10456 1994 Max IV JPSwift1
    10458 1994 Max IV Busarider07
    10530 1994 Max IV Finmad 20 HP Kohler Magnum
    10586 1994 Max IV Phabib
    10621 1994 Max IV Steelheart
    10682 1994 Max IV Smurfwarrior
    10703 1994 Max IV Markfrostyswater 27 HP Kohler
    10732 1994 Max IV Sgtlane04901
    10904 1994 Max IV Jacobsrf
    11386 1995 Max IV Millerperf
    11530 1995 Max IV Countrycummins99
    11582 1995 Max IV BadBradII
    11640 1995 Max IV MAMudslinger
    ????? 1996 Max IV Heaven's Pavement
    12002 1996 Max IV Dozerlarry
    12300 1996 Max IV Hiballer211
    12488 1996 Max IV StoneyRidgeBoy
    12896 1996 Max IV Coyote
    13287 1997 Max IV Hawksmore
    13387 1997 Max IV Miller Time
    13879 1997 Max IV JoshV 20HP Kohler
    13976 1997 Max IV Cabinfevrr
    14131 1997 Max IV Plumcrazy
    14307 1997 Max IV Shelbyjr 16 HP Vanguard
    14428 1998 Max IV Jtb51b
    14850 1999 Max IV Rcopes
    15616 1999 Max IV Liflod
    16010 1999 Max IV Antonio
    16228 1999 Max IV Tennesseemudbug
    16258 1999 Max IV Newtwo6x6
    16398 2000 Max IV Amphibious Drew Factory 16 HP Vanguard upgraded to a 23 HP Vanguard
    16564 2000 Max IV Sasshoc 900T
    16675 2000 MAX IV Carpaltomo 18HP Briggs & Stratton
    16730 2000 Max IV Srpdbanshee
    16936 2000 Max IV Freestyle7783
    16954 2000 Max IV Ken White
    16999 2000 Max IV Kjmax4/Fmints
    17165 2000 Max IV Xbunsenx
    17319 2001 Max IV JPSwift1
    17573 2001 Max IV Wheeler
    18204 2002 Max IV Amphibious Drew
    18536 2002 Max IV Kghills
    18837 2003 Max IV Drooper
    19117 2004 Max IV Ww2imposter 25 HP Kohler Command
    19274 2004 Max IV (for sale) Factory 23 HP Kohler
    19679 2005 Max IV Rusty-Gunn Factory 25 HP Kohler Command
    19838 2006 Max IV Hack4Life 27 HP Kawasaki
    19855 2006 Max IV Msafi65
    19987 2007 Max IV DWdog51 27 HP FD750D Kawasaki
    20048 2007 Max IV Hideous 4x4 27 HP Kawasaki
    20202 2008 Max IV Madtrapper 29 hp Kawasaki EFI
    21425 2014 Max IV akcrawler Factory 29 HP EFI Kohler Command
    MUDHETTSC15021698 2015 Max IV Drb
    8331 1989 Buffalo Noelchico 18 HP Vanguard
    9157 1991 Buffalo JPSwift1
    15065 1998 Buffalo BuffaloChuck
    19350 2005 Buffalo Argojim 23 Kohler
    19352 2005 Buffalo Argojim 23 Kohler
    19353 2005 Buffalo Argojim incomplete
    19424 2005 Buffalo Argojim incomplete for the moment 23 Kohler maybe
    19427 2005 Buffalo Argojim incomplete
    19571 2005 Buffalo Argojim 23 Kohler
    20277 2008 Buffalo SOLD/Unknown
    20356 2009 Buffalo Ktcole
    20718 2011 Buffalo IanPNG
    20739 2011 Buffalo IanPNG
    10395 1975 RIM Don
    10442 1976 RIM Liflod
    10539 1976 RIM Millirad
    10544 1977 RIM Brentelsheiemr
    10586 1977 Rim ArgoJim
    Total Max Count thus far: 178
  7. #367
    Just bought a MaxII and was told it was a 2001. This was sold to me by a guy who rebuilds these as a business and supposedly was friends with the owners of the company. Imagine my surprise when my serial number comes back to a 94! He was only off by 7 years! MAXII S/N 11056 1994
    On edit, It has been pointed out to me that this post may be confusing. Just to be clear I got the date list from a chart I found on the internet and the dates on here just verified what I found out from there. The chart is shown below on someone elses thread and I also have ity linked in a post further down.
    Sorry for any confusion.
  8. #368
    Jan 2014
    clifton IL
    813
    Quote Originally Posted by rickf View Post
    Wow! May as well put his name out there so someone else don’t get the shaft too, that’s not right to do that crap. I’m sure if he rebuilds these things he knows exactly what year it is!! Unless he changed the upper body! Just not cool.
  9. #369
    When I pointed it out to him he told me he got the info from a well known supplier of max parts that I am sure we all buy from. I kind of doubt that since it was his S/N list that led me to the real date but I am not a person to sling mud. When you think about it what is the difference between a 94 MAAXII and a 2001MAXII? The body is the same as far as I know, It has a 18 horse Briggs in it with the large axles. Other than the year what is the real difference? The seller is supposed to be setting me up with some spare tire and another set of control sticks since I had some trouble with it and he does feel bad about that so I don't really think he meant to deceive me. He did offer to take it back for a full refund, not like "It's yours, you bought it". And for what I paid in this area, they are very hard to find around here, in any brand for that matter.
    When I said he does this as a business I meant he does it out of his garage and he travels around buying them as he finds them. He does not have a full time garage doing it.
  10. #370
    The major difference would be splined axles and inner bearings versus bolted sprockets and inner bushings along with round head lights versus rectangular head lights.
    Since you have posted this on this thread, could you please clarify it was or was not this "list" that lead you to the year determination.
    Hate to see Cory member cbass be associated/besmirched with this if not so.
