Max IV tire rubbing
Results 1 to 10 of 17
Thread: Max IV tire rubbing
    May 2013
    Benton, Maine
    63
    Max IV tire rubbing
    My front tires on my Max IV seem to be rubbing. Is it bearings or tub sag?
    Mar 2014
    Lake City, Florida
    288
    Is the body sagging? I'm not the resident expert mind you: jack up the offending side and see if there is up and down, side to side play when you shake the tires. It thats not an issue (and the body is sagging on that side) then just jack up the side thats sagging and leave it in the hot sun for a day and night. Then take off the jack the next morning.
    Texas
    2,161
    Looks like the tire is over inflated.
    Aug 2013
    Hilton head SC
    315
    Yup too much air pressure... Norm
    Mar 2014
    Lake City, Florida
    288
    See, i told you i wasnt the resident expert
    May 2013
    Benton, Maine
    63
    I have 10 psi in them. How much do you think I should have?
    If you have k-lock wheels, then run 1-2PSI. If you have the older non k-lock wheels, run 4-5PSI to help keep them on the wheel.
    May 2013
    Benton, Maine
    63
    And do not sweat it I'm learning every time I work on it. Go Black horse!
    May 2013
    Benton, Maine
    63
    I will try 5 psi thank you all
    Quote Originally Posted by sgtlane04901 View Post
    I just looked in your gallery and you have the newer k-lock wheels.
    By all means, do not run 5 PSI. Get a low pressure tire gauge and run a true 2 PSI. There is a HUGE difference in ride quality and since you have the k-lock wheels, there is no reason not to lower the pressure that much. You just have to make sure you have a low pressure gauge, otherwise the reading won't be accurate.
