johnboys max 2 highboy
Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 42
Thread: johnboys max 2 highboy
  1. #31
    Nov 2013
    st cloud florida
    91
    looks interesting,keep the gears turning!
  2. #32
    Feb 2011
    michigan
    352
    Does your machine still float?I still plan on doing this mod but I probably wont if It wont float.
  3. #33
    2,632
    flippy, it floats just fine. seems to swim a little better but those tires with the adair tracks never did swim well. i will probably design a couple of quick install wheel paddles for swimming although i,m not in water much. the high frame design let's me go in deeper water before it even starts to float anyway. johnboy va.
  4. #34
    Feb 2011
    michigan
    352
    awesome,thats what I need to know seeing as I would be on lake st clair in the winter.I bet sitting up high keeps the tub from bottoming out in the snow also.Makes me wonder if tracks would even be necessary.With your lift it seems that wheel extensions are not needed either.
  5. #35
    2,632
    yes, there is plenty of clearance. i kept the axles the same distance apart as they were. if you spaced them 28'' to 30'' apart you could run 3 26'' 0r 28'' tires on each side. that would set you up even higher ground clearance. if you do build it i will share what design finally worked the best. all the bugs are out now. j.b. yes there are no wheel extensions needed either.
  6. #36
    2,632
    see the highboy in video at busco oct. 2015 gathering. j.b. ( still performing great, just added 4'' of belting on the tracks for deep snow )
  7. #37
    2,632
    max highboy and the snow
    got the new 21 h.p. vanguard and new drive clutch installed this afternoon. already have 6'' snow and will get maybe 24'' - 30'' . can't wait to see how it goes. took a short run and it feels like a new machine again. wiill get some pics over the weekend and everyone else having snow....... have fun !!!!! johnboy va.
  8. #38
    May 2014
    Talkeetna, AK
    155
    I just watched the videos. That thing is truly impressive. Getting the tub above the mud makes all the difference. Good work.
  9. #39
    Feb 2011
    michigan
    352
    how do I find the video?
  10. #40
    2,632
    thanks a.k. she plowed thru about 24'' of snow today with the adair tracks to which i added 2'' belts on each side of each track. that might be it. we have 36'' now. thats up to the top of the tub and it's powdery snow. i think i would need 24'' wide tracks !! i like the 21 hp vanguard. can feel the extra 5 hp and the new drive clutch is much smoother than the 15 yr. old. one. be a couple of days to plow out. johnboy va.
