Normal speed?
Results 1 to 10 of 31
Thread: Normal speed?
    Jul 2014
    Mississippi
    82
    Normal speed?
    Guys I have a max iv with an 18hp b&s v-twin. My top speed is only 15-16mph. Is this normal? If not what should a look for as far as getting it to normal speed?
    Jul 2014
    Mississippi
    82
    45 views and no replys? Come on guys I need some help.
    Sep 2012
    Hanover,PA
    1,012
    speed
    First thing I would look at is the drive belt. Make sure it's Not worn Thin. That will reduse your top speed and pulling power.
    Alot of guys on here are out rideing and at events so getting a responce around this time of year is sometimes slow !
    Make sure your drive and driven clutches are free and moveing also.
    Plus everything id Lubed and free !
    Hope this helps you some.
    Tj
    Jul 2014
    Mississippi
    82
    Thanks for the reply. What would you say i should normally be running top speed?
    Sep 2012
    Hanover,PA
    1,012
    What size tire you running ?
    The 22" will be slower thaan the 26" for sure.
    I don't have a Max 4 so I can't realy say for sure. But I just wanted to give you some things to look for.
    2,632
    kinda simple but also make sure throttle cable opening throttle all the way. john boy va.
    Meadville, Pa
    3,286
    Yeah check for full rpm. You should be getting about 3750 out of it. Too much more without the high speed kit will float a valve.
    Jul 2014
    Mississippi
    82
    I have 25" tires on it. How do I check my rpm?
    You can purchase a tachometer to check your RPM. I would start with the belt like wedge mentioned though. Make sure that it has the proper tension. You can tighten it up by adding spacers under the engine. As for the top speed, it will probably be in the mid 20's, definitely more then you are getting.
    Jul 2015
    Florida
    57
    I not sure how fast they are suppose to go, 16 mph may be about right. i think that is all mine would do. I think the factory says 20. the point is there not fast machines.
    Max IV
    Dodge Ram 2500 4x4
    swamp buggy powered by 1947 willys flathead
