Is the fuel in a Max 2 gravity fed?
Results 1 to 3 of 3
Thread: Is the fuel in a Max 2 gravity fed?
    I'm reassembling my Max 2 basket case and wondered about the fuel pressure. Is the fuel gravity fed? I haven't got the fuel tank in so I can't tell.
    The Max II sort of is, the tank feed on most is at the bottom though there is a pump usually mounted on the engine. Without the pump the machine would starve off camber or descending.
    An inline shut off valve is good to have and come on most later machines.
    Thanks ArgoJim. I'm just finding my way as I assemble this. I found the fuel pump, tested and installed it. Little by little.
