74 max 2 chain and sprocket upgrade ???
Results 1 to 10 of 13
Thread: 74 max 2 chain and sprocket upgrade ???
    Jan 2014
    clifton IL
    813
    Ok guys a few questions about changing the #40 chain and sprockets to #50 chain and sprockets and will it interfere with the brake drums and such?? We're thinking about swapping thses sprockets out and looking for any advice before we start buying parts.
    Thanks for any input on this!!
    Dave Phelps
    Oct 2008
    Summerfield, NC 27358
    196
    Racers don't need brakes. They only need extra strong throttle cable and hard grip to keep it wide open.
    Grand Island NY
    330
    50 chain will be fine. The only problem is you have to change the chain adjusters
    Jan 2014
    clifton IL
    813
    Quote Originally Posted by frabbit View Post
    lolol yes frabbit you are correct!! but this is my buddys machine and the sprockets are iffy at best and we discussed a 50 chain sprocket and chain swap and was hoping someone out there in the 6x6 world has done or tried this already.
    I've come to the conclusion that my body may not be able to take me driving a racer!!! Ya know old and fat!!
    Dave Phelps
    Jan 2014
    clifton IL
    813
    Quote Originally Posted by egoperf View Post
    egoperf do you happen to know the tooth size on a 50 chain sprocket compared to a 26 #40 sprocket?? And change adjusters how?
    thanks
    Oct 2008
    196
    Does he want to trail ride or race?.....Help him out, it's need to know. Sorry,went to look in the garage. We did one of grandkids, can't see in there yet
    Same with the still half full trailer. Just moved in Nov.1. will try to find out.
    Fairbanks AK
    1,456
    My old II is a 74and I just installed a newer set of sprockets and tensioners for the wheel chains. I'm not sure if all that is different on tensioners is the slide block. I can't find any # 40 tensioners in the spare parts pile to check out. Maybe someone else knows if the rub blocks are the only difference.
    Sep 2012
    Hanover,PA
    1,012
    It has to do with the rub block. The #50 is Wider than #40 chain.
    That's the only dif .
    Oct 2008
    196
    Wedge are you talking about the old style, that bottom of chain BB rides on? Tom put adjuster sprockets similar to rims/max4s.
    Sep 2012
    Hanover,PA
    1,012
    I was referring to the Nylon blocks that the chain rides on. The #50 take a wider block as it is wider than #40 chain
    The max II used them on the bottom pulling UP in the slack side of the chain.
    If your running a sprocket then you need a #50 sprocket over the #40.
    I am not sure exactly what he is using ?
