Chain Slack
Results 1 to 5 of 5
Thread: Chain Slack
    Chain Slack
    I just picked up a 1991 max II and the chains are tightened but they still hit the bottom of the tub. Do I need to replace the chains?
    Jun 2014
    Smithfield N.C.
    782
    Ben, I am not a MAX guy but if you have your tensioners as far as they go and you are dragging on your plastic, time to get new chains. That is just my thinking. There are 1000 or more Max guys on here, they all know more then I do about a MAX. Sounds like you have a lot of play in the chains.
    Ok thank you I’m going to get new chains soon
    2,631
    i too would say they are stretched all the way . make sure and get good quality chain that will last . i bought my max chain from '' roller chain for less ''. it's good prices also . 800 356 2336 . johnboy va.
    Sep 2010
    rhode island
    709
    Yes on new chains I'm an argo guy but chains are chains. You should also look at your sprockets for wear. When I did mine I thought just chains till they came off and more of the sprockets were revealed and lots of shark fins for teeth.
