Axle Bearings - Can u buy @ local store?
Results 1 to 6 of 6
Thread: Axle Bearings - Can u buy @ local store?
    I would think that with most bearings you can find them just based on the part number in the side of the bearing...Has anyone done this? Does anyone have the bearing part numbers for outside MAXII (year 2001).
    Your best bet is to contact Buffalo Bearing (716) 874-1720. Many 6x6world members get their bearings from them and they have very good luck with them. They are inexpensive and high quality. A 2001 Max should have 72mm outside diameter bearings with 1.25" inside diameter.
    Mar 2009
    Alabama the Beautiful
    888
    I have a 96 maxll with 1 1/4 shaft and it takes an HC207-20 bearing.I got it at my local bearing co for $14.
    Make sure you measure the outside diameter of the bearings because I believe pre 1998 Maxes used 62mm and later models used 72mm.
    Mar 2009
    888
    The hc207-20 is 72 mm,I was told by Ri that serial number under 14000 had the small bearing.My 95 and 96 has 14000+ serial number.
    62mm bearing part number
    Hi, do you know the part number for the 62mm bearing?
