Every time i get in the water with the maxll i have to slide to the right side of the seat to level out the machine.So i turned the levers to the right side so that i can sit on the right side and drive.Man this worked out great,I pulled the levers out ,turned them the opposite and had to trim the floor pan a little and turn the throttle lever around in the right direction.The only problem is the grab handle for the passenger on the dash is now in front of the driver.I haven't tried it out in the water but i'm sure it will balence out good.
