Max II Jack Shaft ???
Results 1 to 9 of 9
Thread: Max II Jack Shaft ???
    Jan 2009
    North Mississippi
    158
    Quick question. How much, if any, play should there be in a Max II jack shaft when the chains are off? On mine you can slide the sprocket assembly back and forth on the shaft. It’s almost like it needs more washers/ spacers between the sprocket assembly and the frame. Should the sprockets slide back and forth on the shaft? Will this movement stop and self align when the chains are tight???? One more question, I’m pretty sure I already know the answer. Is there any built-in misalignment with the jack shafts and the T-20? I’m new to the Max and just want to know for sure that I’m fixing this thing the correct way.
    Aug 2008
    High Level ,AB , Canada
    369
    ive had the snap rings that hold the sprokets in place pop out of their groove and this alows the sprokets to slide on the shaft ,check to see if your max has snap rings holding them in place
    Dec 2007
    eden nc
    1,484
    Quote Originally Posted by duckhunt81 View Post
    no snap rings on jackshaft . . but should be 2 cotter pins on one end it's betwin the washers and the mount inboard end the outside should be in the mount and through the shaft . robbie
    Jan 2009
    North Mississippi
    158
    With the cotter pins in, the jackshafts will still slide back and forward....I would say that there is about 1/2" or so play.
    Dec 2007
    eden nc
    1,484
    need some more washers . pm hey dan he works at max. he can tell you the right number to have at each end . mine has been apart so maney times it's probley not right . it needs to be alinding with the center sprocket abd the tranny . robbie
    Phoenix,Az.
    1,629
    The next Max II I build won't have a Jackshsft.
    I hate the jackshaft
    Whipper
    Dec 2007
    eden nc
    1,484
    Quote Originally Posted by whipper-ag View Post
    Whipper
    i 2nd that motion . show me the way whipper . thanks robbie
    Pittsburgh, PA
    695
    I learned from Whipper - add a washer to each side until the chains are lined up - or better, find a way around using the jack shaft.
    statesville, north carolina
    2,604
    Whipper
    next winter Beth's max is getting tore down to replace the lower tub. when it goes back together there will be a few less moving parts as well
