The Kohler 23 Command does need warming up like Mike said as well to drain instead of a plug at the base in the rear is a valve.To open it you twist it (counter-clock wise I think) and pull it towards the rear of the machine about 1/2 inch.When done push back in until it stops and twist it one quarter turn to close.When you look at it close you'll see how it works.
