First Terra-Jet Project, for a Newbie
Page 1 of 10 1 2 3 ... LastLast
Results 1 to 10 of 91
Thread: First Terra-Jet Project, for a Newbie
    So, just as the title suggests, I picked up this 453 without any prior knowledge of these vehicles.
    https://photos.app.goo.gl/sjawu88i2o52b2DC9
    I'm looking for some tips as to what I should be looking at/addressing first. I can see that there may be issues with the transmission:
    https://photos.app.goo.gl/YZBggpwWvx36Huxf9
    But it also came with this:
    https://photos.app.goo.gl/a1X3Y4YZ8jyhDEXu9
    The bottom of the tub looks to have a fairly fresh coat of paint on it. The inside too, although it looks like it was exposed for a while and has started to rust again:
    https://photos.app.goo.gl/TM8DB2HvfuoEeMLq7
    To start cleaning it up, should any of this get cut out and welded back in after?
    https://photos.app.goo.gl/19dP4WjzN4JytbU56
    I'm just looking for some direction here, on the best plan of action, so that I can do things in order and not have to go back and do it twice!
    Thanks!
    So, no response yet, which is fine, but here's an update while we wait.
    Pulled off the hitch and whatever these other things were tonight:
    https://photos.app.goo.gl/fCeU5dRRNEj63UNk8
    Feb 2016
    Mississippi
    1,108
    That's a neat looking rig. I don't know anything about the transmissions used in those machines.
    You ask for direction - a best plan of action. The answer depends on what you want this machine to be. I personally like to know my machine inside and out, particularly if I'm relying on it to get me way out in the mud and back. So I tear things completely apart and then reassemble, repairing and repainting and improving functionality along the way. Hopefully someone will be able to tell you whether or not the transmission is ok or junk. Good luck and keep posting pics.
    Thanks DirtDobber, I agree, going through it piece by piece will provide the best knowledge of the machine and I will keep posting as I go, to hopefully help others. I'm just looking to clean it up and repair/replace whatever needs to be. I think at this point I'm going to try and remove the body to get everything cleaned up and the transmission likely swapped out. If anyone can offer any tips on that, I'd be very greatful. Thanks!
    2,634
    they are cool looking machines and seem to be quite capable offroad .. some neat videos under terra jet aatv. viddeos. johnboy va.
    A couple of updates: Looked a little closer at the tranny and it's more broken than I originally thought:
    https://photos.app.goo.gl/CHfgZS5c7sahXxSR7
    I unwrapped the spare transmission and it appears to be a different year...
    https://photos.app.goo.gl/KLgV1SPWJKqq7y1K8
    Can anyone say if there's going to be any compatibility issues?
    Also, the bearings and seals are missing, but the shaft is really messed up:
    https://photos.app.goo.gl/aV8ZM62hJM4RhhJC7
    I think I may have to open the case to get it out, the 'Hub' sleeve thing looks pretty chewed up and might even be welded to the axle. I hope the hub in the original tranny will be compatible.
    I've also been trying to get the axle out of the vehicle. The bearings and sprocket and collar have all been loosened up and seem to slide pretty good, but the axle in the tranny doesn't want to budge. I'm trying to hammer it out the driver's side, but I can see the key on the right and it doesn't seem to be moving at all. Been spraying it often, but any other tips?
    https://photos.app.goo.gl/51oy81fGXXkz4PSX7
    Also, I had to cut the driver's side bearings out...
    https://photos.app.goo.gl/Y81bx2VBjXDAJ2k9A
    Had my helper giving me a hand tonight, he's super excited and looking forward to getting it running.
    https://photos.app.goo.gl/rB7Vtx85ZRWUhKf39
    Also, I haven't been able to budge the axle at all in the trans. Based on the tools that I found in it, I'm going to have to assume that this is where the previous owner gave up. I put the puller assembly on it that I found, to keep tension on it and I've been spraying and pounding away at it.
    https://photos.app.goo.gl/Ld2vdkamAxxks4wv5
    I'm going to try and get it to slide to the passenger side, because I think the key may be distorted and jamming it in place. Then I will try and get it to go to the left and out. I tried heating it last night too, but it's cold out and just seemed to make it sweat, which may make it worse!
    Open to any suggestions!!!
    Still banging away at it. The shaft has not budged at all in the tranny. It has been suggested that I heat it more, to try and loosen it up. Not sure if there is danger of me warping it or anything, but I will give it a try again. I'm wondering if it's the bearings in the side of the tranny that are stuck and I should try popping them out first????
    Pittsburgh PA
    1,153
    I wouldn't risk damaging something that you can't replace. If you can take more of it a part, your're better off.
    Feb 2016
    Mississippi
    1,108
    I couldn't agree more. Goach if you further disassemble it you might find the problem. I notice in a previous post you mentioned your heating the part was only making it sweat. This is completely ineffective. You need a substantial heat source that can apply lots of heat quickly -- to the right part. The problem is you don't know what the right part is (and neither do I). If a rusty bearing is the problem, you want the heat on the bearing race to make it expand, with as little heat as possible on the shaft to keep it from expanding.
