Update to the KID. Engine and powertrain installed and triple chain hooked up. Body is repaired and should be water tight. I went with flat camouflage tan for the body color. The black areas is rustoleum truck bed spray liner, added a good rough texture and scratch proof. I found a 6ft wide snow plow. I cut a receiver hitch out of wrecked ford expedition that I will use for the front mounting. I have to make a new support bracket for the front. Plan to use a 12v winch to lift the plow. With the receiver hitch I will make a removable mount for the winch to move from the front to rear if needed. Getting closer to driving this beast!
