No one has anything to say about these plans? Maybe no one knows what I am referring to, so here is a link:
~ Build Your Own 6x6 ~
I haven't made up my mind about this thing, and I was hoping for some input about it. My 2 biggest issues with it, without having seen the plans, are that I don't know how available the transmission drive is, which one to use or it's cost, and what some inexpensive wheel / tires to use. If the trans and tires cost too much, I may be better off buying and older 6x6, but then I have the issue of not being allowed on the ORV trails. Plus, if I make one myself from the plans, I can incorporate a cab into the design so it's covered and heated.
I'm a little bit familiar with fiberglass covered wood boat construction, and I think the plywood hull and body would be just as good as any plastic or plain fiberglass body. The specs on the website say it's curb weight is 300 pounds, but I don't know if I can believe that - maybe, but I don't see how 6 wheels, engine, all that wood and miscellaneous stuff can only add up to 300 pounds.
I know I could get a used 6x6, but there is the width issue, and if I built one of these, everything would be new (ie harbor freight engine with warranty), except for the transmission.
I would sure be nice to get some practical advice from some people who know more about this design than I do, or at least some opinions.
