Can’t seem to post a picture from my phone (no surprise there lol)
Good Evening just wondering if your machine has all 6 wheels powered with a hydraulic wheel motors, I have a Hydro Traxx TJ625 and it has only 4 wheel motors,one on each corner. Would you know if I could add two more wheel motors, looks like the frame has all the holes drilled to take the wheel motors.I am also wondering if the previous owner may have taken them off ,to use as replacements. I run my engine at full throttle when using the machine.You are right about not alot of information available for these machines. Thanks Steve
Mine only has 4 as well. I was told this is standard on these units. Apparently the motors are pretty pricey at around $500 / each.
I’ve been running it at less than 1/2 throttle so far. I suspect the tach is lying because at 1/4 throttle it’s pushing 3000 rpm...being that it’s a diesel I don’t want to red line it lol. Going to check out the tach tomorrow and go from there
Good evening allwheeldrive there is no power to the centre wheels they just spin free Thanks Steve
It sounds like your machines are set up to run tracks, usually only the corner motors are used when tracks are installed. Did your vehicles come with tracks?
Good Evening Marauder yes it has the smaller wheels to run tracks, when i got the machine I was getting the tracks also,but someone stole them . I am looking to build a set for it if the machine does not sell. Thanks Steve
Hi Steve,
Chances are, if you can't find two more hydraulic wheel motors for the center positions you will most likely have to get tracks for it if you want to sell it because most people won't want to buy it if only the corners are providing the traction, unless you sell it low enough so that whoever buys it can either source out the two additional wheel motors or track. Good luck.
