Amphibioius Atvs Logo
Go Back   6x6 World > 6x6 ATVs > Other AATVs
Other AATVs Specific Discussion for all other Amphibious ATVs including Amphicat, Camel, Coot, Jiger, Scrambler, Starcraft, Terra Tiger, etc.
Reply
  #21 (permalink)
Old 08-30-2008, 02:51 PM
riotwarrior riotwarrior is offline
Sophomore Slider
riotwarrior is on a distinguished road
Quote:
Originally Posted by Amphiman1 View Post
Hi , interesting trans,,,,,,different than mine,,,,,hum. need to find one more, then we can be 3 muscateers i have the big black box of mystery......
Well now thats funny......ROFL...So what does your transmission look like? How about some pictures? How well does your unit work? Do you have a propeller on the rear of your AATV like I see in the brochure?
I tried to open the driven clutch and no luck, the whole setup is mounted on a steel plate and the belt would not come off the clutch due to clearance. It appears I have to remove the driven clutch attached to the transmission to get the belt off. So that being what it is, do I just undo the center bolt on the clutch?
__________________
12 HP Muskateer 6x6
90 Bronco 5.0L 4sp currently stock truck
(converting to)
94 diesel 7.3 IDITIC + 4sp
Dana 70 rear, 60 front
Osoyoos BC Canada
Al "Camo pants"
It's TOO late to read the book on how to swim when the boat's going down
  #22 (permalink)
Old 09-14-2008, 10:09 PM
Sophomore Slider
Muscateer chains and axle bearings
Ok well I removed the front chain guards and on the L side I noticed that several rollers where missing on the chain. I measured the chain for one side and it is near about 16' total for 3 chains on one side. I have no idea what the chain size is as, it is not marked.
How do I determine what chain I need to get?
I pulled the front sprocket, and axle to discover a semi sealed tapered roller bearing on both inner and outer axle portions. The # on the seal is Timken L 44600L, the actual bearing is L44643LA, I will update with a seat # once I have it removed from the axle housing.
It looks to me like I'll be replacing all the chain and doing 12 bearings too....JUST 4 GOOD Measure! Now I just need to find 12 bearings so I will start to check locally for them and branch out from there.
http://i198.photobucket.com/albums/a...ithbearing.jpg
http://i198.photobucket.com/albums/a...veSprocket.jpg
http://i198.photobucket.com/albums/a...llyremoved.jpg
http://i198.photobucket.com/albums/a...ngsealside.jpg
http://i198.photobucket.com/albums/a...er/bearing.jpg
UPDATE
Pulled the race, has what appears to be # of 0-L44610 on the side and I can see clearly it is a Timken product.
__________________
12 HP Muskateer 6x6
(converting to)
Osoyoos BC Canada
Al "Camo pants"
  #23 (permalink)
Old 09-15-2008, 09:01 PM
Sophomore Slider
Bearing and chain help
Ok well I removed the front chain guards inside the tub and on the L side I noticed that several rollers where missing on the chain. I measured the chain for one side and it is near about 16' total for 3 chains on one side. I have no idea what the chain size is as, it is not marked.
How do I determine what chain I need to get? The chain is 9/16" wide outer side plate to outer side plate and 1/2" from pin centre to pin centre.
Image hosting, free photo sharing & video sharing at Photobucket
See the images here as well
http://i198.photobucket.com/albums/a...owspitting.jpg
http://i198.photobucket.com/albums/a...idebyside1.jpg
http://i198.photobucket.com/albums/a...idebyside2.jpg
http://i198.photobucket.com/albums/a...idebyside3.jpg
http://i198.photobucket.com/albums/a...cetogether.jpg
http://i198.photobucket.com/albums/a...ngsideview.jpg
For all the images I have thus far for my little rig check out my photo bucket
riotwarrior/Muscateer - Page 1 - Photobucket - Video and Image Hosting
__________________
12 HP Muskateer 6x6
(converting to)
Osoyoos BC Canada
Al "Camo pants"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
