I would change those T pins as they will not get any better with time.
Buy oversize hardened dowel pins, .002 over, McMaster-Carr has them, and a reamer to get an interference fit.
Press them in, not hammer in.
Printable View
Thanks for the advice everyone. With the shifting levers removed I got the transmission to go into reverse with a screwdriver. So i made a replacement pin for the left side and put it back together and IT WORKS!!! Again thank you guys for all the great advice.
The next thing i need to do is fix the holes and small cracks in the tub. What's the best way to repair the plastic in these old machines? What kind of plastic is it?
http://www.6x6world.com/gallery/data...126_161635.jpg
http://www.6x6world.com/gallery/data...126_161645.jpg
its ABS polyethen yaa cant match it..you gott to get crafty with general plastic and cloth resin....your hole...you should go about what i did it worked great with inginuity and some different materials of apllied techichs ile have to explain it in a email to ya personally
you should also get rid of that old style clutch from the engine to belt the comet clutch newr style work better
The older brittle bodies are ABS and can be repaired with ABS melted into a goo with acetone and reinforced with cloth.....Or with special epoxy, and cloth makes that easier too.
The HDPE (high density polyethylene) was used in the newer bodies more mid to late 70's.....That is better repaired with the epoxy. I've had mixed results with plastic welding.
https://www.youtube.com/watch?v=2a5RlcP-4JE
You could send the t pins to me if wanted. Lol
The epoxy holds up very well, just remember to follow all mfgr recomendations on prep. Clean, scratch, alcohol clean and flame treat prior to application and it will adhere well. Every material has it's limits on flexing and something caused the cracks/holes to begin with so reinforce as needed. The beauty of epoxy is 2 dissimilar materials can be adhered together. You could use sheet aluminum or HDPE as patch material.
