Originally Posted by
chris davison
Hey guys I have an idea for my rear prop drive that some of us might try, give me your opinions on this. You know how a double wishbone suspention works in the front end? picture it with an air cyl instead of the shock and a prop instead of the tire. picture it on the back of walley. now I can pull it up out of the water until it is almost straight up. The prop will still be facing backwards just like your suspention hit a bump. but the air cyl will pull it up higher than that. Your drive shaft with the universal joints and the sliding splined shaft will all move to accomodate any position. Now the prop can turn from right to left just as the tire does for steering while the drive shaft powers it. What do you think? I should be able to build this fairly easy.
