Couple new pictures.
[IMG]http://www.6x6world.com/gallery/data...s/IMAG2489.jpg[/IMG]
[IMG]http://www.6x6world.com/gallery/data...s/IMAG2491.jpg[/IMG]
Everything is so crooked. I am using lead weights to try to make it straight, but its unlikely to work. Either way, by the time I am done it will hold water again, or better yet, keep it out.
The outside patches are mostly going to get sanded off so it has its smooth factory look. The thicker patches will all be on the inside. There was soooo much delamination that some of the 'small' cracks had to get ground out 1/2 inch, so I am stuffing FB into the cracks, letting them dry and grinding off just to fill, instead of just going over the voids, which is what the previous guy did...
It is taking a while, as I have to wait for everything to dry between set ups. The West System Epoxies, do not like being used under 20 degrees, which we are firmly in now! So the whole project got moved into my garage, which is about 21 degrees. Just making it!
C
You never know what you are going to find.. Today I turned up an original Bazoo Brochure and a can of original OTACO Bazoo touch up paint, orange of course.
Also found a place that has the Coil cover I need NOS, still in its little bag from 50 years ago.
Good day.. Lol. I will post some pics when I get it!
C
Well here is the product lineup
[IMG]http://www.6x6world.com/gallery/data...harachters.jpg[/IMG]
And the outside profile is done. I know it doesn't look like much, but once filled and the inside is done its going to be factory beautiful, aside from some warpage, which I cant do anything about :(.
[IMG]http://www.6x6world.com/gallery/data...de_profile.jpg[/IMG]
C
Nice Find
Did you buy it off Kijiji?
I'm in southern Ontario and have 2 Bazooo tubs.
One is brand new never assembled.
The other I drive around here weekly and it's a blast.
Transmission In mine looks like a snowmobile trans
with reverse. Brakes look like old arctic cat parts.
If the clutches are siezed (like mine was) it won't turn properly.
Adjustment of the clutches is done by adjusting the spanner nuts on the clutch shaft.(set screw in the nuts lock them to the shaft)
When it's set up properly you will have true 6 wheel drive and be amazed at what it will go thru or over.
Check out my gallery pics
Hey bazoo guy!
Yes found it on Kijiji. 5 minutes from my house no less.
Did you get the tubs from an auction in Orillia? I know that there was a couple that sold in Nov/Dec 2015...
I have to say, I am very happy about having it back and operational!!
C
So you haven't heard anything from me in a while, but still working on it!
My 'regular' work life has been smashing me, and haven't had the time to work on Bazoo as much as I wanted...
Stay Tuned!
C
