1991 Magnum 8x8
+ Reply to Thread
Results 1 to 7 of 7
Thread: 1991 Magnum 8x8
  1. #1
    1991 Magnum 8x8
    I joined the forum not knowing if you allowed 8x8 argos. My problem is that one of the axles keeps slipping out of the bearing. All the others are OK. There are only 2 set screws holding it in place. Has anyone had this problem and solved it...Thanks
  2. #2
    Join Date
    Feb 2013
    Location
    shenendoah valley,va.
    Posts
    2,633
    pemac 1 welcome to the forum .... all the aatv's are welcome here !! glad you joined and you will get plenty of friendly help here. i have a max, so can't help you with your argo but stay tuned !! many will reply. johnboy va.
  3. #3
    Join Date
    Feb 2013
    Location
    Posts
    2,633
    also where are you located ?
  4. #4
    hi 1992 Argo magnum owner here,there are 2 bearings (inner,outer) and all together there are 4 set screws that bite the axle keeping bearings in place. pull the axle and tighten with blue lok-tight applied and you should be good!
  5. #5
    San Ramon, California
  6. #6
    Do you put the lock-tight just on the set screws or on the axle as well.
  7. #7
    just the set screw put anti seize on the axle!
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
