The Gaganator Project
Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 94
Thread: The Gaganator Project
  1. #21
    Cayley, Alberta
    472
    Wipper,
    as for the CV axle angle, I have done some research and it looks like the max might be 45deg. To me this seems a little steep... and of course, it depends on the build. 25degs is another max I've heard (I've also heard of a 90deg CV joint )... so, basically, I'll take it as it comes.. if it's too steep, I'll lower it, if it works.. It'll keep it in place. The animated gif looks like a good 45.. but mine arn't built like that (I've got three rollers and the rollers are locked in place). Meh.. design - no matter how hard you try to make it real often comes to somesort of rig job to make it work (just a little less riggin :P).
    As for the clearance, I've got about 10" right now in the center- but that's on blocks.. so maybe minus an inch or two under load (and softer springs), plus 2" from 25" tires.... probably comes to exactly how it sits now... around 10"
    I have thought about tub design, and the basics are as the beginning drawings... but I plan to add more "anger" into the look, maybe with an air intake... and a nice grill. The lights I am thinking to try and incorporate a hot rod style (free standing)... but unsure... I'll probably throw up a couple new designs of the look in a couple weeks.
    Greasemonkey,
    Yeah... I think that's the only way to go. I might add a hoop of round tubing to the top to counter the cut... just to be on the safe side (probably small and bolted on so I can get the axles out in a change).
    Thanks for the input guys... I hope to have more progress in the near future.
  2. #22
    Cayley, Alberta
    472
    A possible tub design..
  3. #23
    I like that, especially the Argo-like raised section of the "hood".
  4. #24
    Cayley, Alberta
    472
    Well, I was in and out of the shop a couple times working on the diff frame and after a lot of frustration I decided to go a different route to hold the diffs. The problem is comming from trying to form my own sockets for the bearings out of 1/4" 3 1/2" tubing, cutting and bending down to the right diameter, as well as with the crappy used snow fence posts I'm using for the trusses (full of bends and what not).
    New approach - find the right sized bi-metal hole saw and make a socket out of 5/8" flat steel, supported directly from the chassis and brace bars to each socket to counter the compression and twisting action.
    I should have pics by the end of Sunday :P
    Last weeks rendition:
  5. #25
    Cayley, Alberta
    472
    The new diff frame in concept form... I've already cut four of the eight steel plates for the middle(s) and bought some tubing to replace the old crappy snow fence metal..... it'll be nice to work on straight stuff again..
  6. #26
    Cayley, Alberta
    472
    some pics of trying to align the sprocket on the diff...
    Last edited by Mike; 01-01-2008 at 05:30 AM. Reason: linked pictures to save bandwidth
  7. #27
    Aug 2007
    near olean, ny
    1,083
    gagonator.....
    praise praise..haha
  8. #28
    3,285
    Beeman ,
    Those pics you posted were exellent ! What kind of camera did you use to take them?
  9. #29
    Cayley, Alberta
    472
    Quote Originally Posted by mudbug3 View Post
    Beeman ,
    Canon powershot SD600. Ever since my first powershot 100, I have always bought canon digital cameras for their compact form and excellent quality.
    As for the project, worked on two more bearing/race pieces tonight - one more left and then should be able to weld up the frame and show some good pics.
  10. #30
    Cayley, Alberta
    472
    Well, the first attempt at metal working the sprocket worked - but I wasn't happy with how unclean it looked. It's hard to get a clean cut with a plasma torch (or I'm just crappy at it :P). So, while working on getting the water/plumbing & electrical working for my washer and dryer (for my house) I decided to use the old gear that the diff used to hold as a jig. Measuring the center hole (that I had cut with the plasma) I found out that it was almost perfectly 3 3/4" in diameter... which was a size that I could probably find a hole saw for. And sure enough, when I was looking for a hole saw to cut my dryer vent hole at 4" I also found one that was 3 3/4". And so, after finishing up the laundry job for the wife, I got to working on the sprocket again.....
    Pic of the first attempt at the sprocket:
    And a bunch of pics showing my second attempt:
    And the final product:
    And a google video of the final product:
    MVI_0944.avi
    Last edited by Mike; 01-01-2008 at 05:27 AM. Reason: linked thumbnails for multiple pics
