Maxrules... Thank you. I wasn't aware the Buffalo used a lengthened MII frame.
This is a reply that i got today from them:
The kit was a frame addition to hold the T-20 correctly, the rear and center sprockets, 4 axles, clutchs were custom along with many other parts.
Cooling system and exhaust was a big issue, see the photos that we still have on the web. I will mark the project "sold out' on the website.
The kit needed to be part of regular production upgrade from the factory, as it was just too expensive/hard work to update completed machines.
Its a shame, because the modified machines were really nice and drove so well.
I know I'm a bit late on this tread but im getting ready to redo the max 4 after the October Busco ride. I'm going to be relocating the t20 and dropping the engine down.. Not really worried about exaust, that's an easy fix.. Just tear it apart and make it better... Didn't mike do this to his max 4? ( if I remember correctly it was a prof job). Norm...
I like the idea of the conversion but gotta believe the engine and tranny are stacked for balance in the water. I fish out of mine a lot with two adults in the front seat and it floats so nice. I think that's why the front axel is further ahead as well. I go 240 and the girl friend..... Well better not say (lol). But it floats nice and level I'd like to see how one floats with the conversion, maybe not much difference. Should be more stable anyway.
Ha ha I'm sure you could find a driver Jim. Larry had really nice setup there. Kinda simple too.
I know one thing richard did was to "center" the motor during the conversion process. When i go in deep water my max 4 will list to the left very easily compaired to leaning to the right, which takes a bit more effort. I still plan to do this conversion on my own since there is no kit for sale. I rarely take my max in the water so thats not a reason for me to do this. However, to get to the rear axles and chains....now there is a good reason to do it. I hate the idea of pulling the motor all the darn time to get to things that should have been better designed from the plant. If its a routine maintance item, it should be easy to access. I'm not a little guy so its pretty tough to fit into the smaller recesses to make adjustments and grease everything. I just ordered the conversion kit from adair argo (for all 6 axles) to go from factory bearings to the larger argo bearings. Thats gonna be fun. But its primarily being done because poor access to the rear axles leads to poor maintaince which inturn leads to premature bearing failure. So i figure if i beef them up and then get the above mentioned conversion built as soon as i can make time, it will all lead to a max thats much easier to work on and has stronger parts in the end.
Sounds like a major renovation. But it will be nice when you're all done. Hopefully you can post some pictures.
Yes, pictures. Very interesting stuff.
