StarCraft
+ Reply to Thread
Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 71
Thread: StarCraft
  1. #21
    Join Date
    Sep 2012
    Location
    Hanover,PA
    Posts
    1,012
    yES I THINK I LUCKED OUT AS THE bEARINGS ARE tIGHT AS IS THE INNER BUSHINGS.
  2. #22
    Join Date
    Sep 2012
    Location
    Hanover,PA
    Posts
    1,012
    1029161635-00.jpg1029161400-00.jpgStarted a rough mock up on engine and fuel cell. Looks like it is going to work out nice but need to lower engine some. But I am looking at making a new engine mount that is adjustable so that should address that issue. I see I need to cut some weld on one sprocket to get the L,R axle out and pull the frame.
    All in all happy with the StarCraft !
    Any ideas or input is Very welcome. Also if ANYONE has a pic of a Factory Racer I would like to see them as I found the factory roll bar mounting holes when I flipped the upper body over.
  3. #23
    Join Date
    Jun 2007
    Location
    Northern VA
    Posts
    2,766
    There aren't very many pics of the racers that I know of, but here are the ones I had.
    [IMG][/IMG]
    [IMG][/IMG]
  4. #24
    Join Date
    Sep 2012
    Location
    Hanover,PA
    Posts
    1,012
    Thank you don !
  5. #25
    Join Date
    Sep 2012
    Location
    Hanover,PA
    Posts
    1,012
    Pulled the front four axles and bearings and front frame section. Got my aluminum plate for my motor mount also. ready to take the upper body to the strippers and then start the fiberglass work at the shop.
  6. #26
    Join Date
    Sep 2012
    Location
    Hanover,PA
    Posts
    1,012
    1113161424-00.jpg1113161425-00.jpg1113161425-01.jpgWell I got the new engine plate and isolators mocked up and set the engine and tranny in to see how the set up will go in. Can you all tell me the best place to get a belt ? also what are my choices on length ?
  7. #27
    Join Date
    Sep 2013
    Location
    Caldwell, Idaho
    Posts
    1,175
    Tidy install
    ST400R ATTEX(Smiley)
    500 Super Chief
  8. #28
    Join Date
    Jun 2016
    Location
    Edgerton, MO
    Posts
    278
    lookin good!
  9. #29
    Join Date
    Sep 2012
    Location
    Hanover,PA
    Posts
    1,012
    trans mount.jpgtrans mount 2.jpgStarted on making anew trans mount and still working on the chain adjuster .
    See the trans pivot's on the front mount an adjusts at the rear to keep the Main chain tight to the rear drive axle.
  10. #30
    Join Date
    Sep 2012
    Location
    Hanover,PA
    Posts
    1,012
    Well as most of you have found out you move one step forward and end up Three steps behind !
    I Roughed in my tranny mounts and Cool adjusters and Really think it will hold up very well ! Then I mount the engine plate . It looks good to go !
    Ok I lower the engine on it and Rough in my belt line up and my belt is WAY to small AND I can't slide the engine forward because it HITS MY TRANNY ADJUSTERS !!
    So now I need a Longer Belt OR a Smaller engine. The Kohler 18 is MASSIVE !
    At this point I am thinking of just selling it and looking into another engine .
    So hear is my progress so far. NOTE: This is a Mock up NOT finish product.tm2.jpgtm3.jpgtm1.jpg
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
