Need: Exhaust manifold for 18hp vanguard Max II with muffler above L.R. tire
Welcome to 6x6 World.
Thanks Mark you are a savior yet again, I sure wish Briggs would post a cross reference parts list, would make things easier sometimes. The manifold I have exits to the front instead of the rear (as mounted in my Max)
That is correct. It passes through the body between the tires. That number exits to starter side # 691562 exits on oil filter side. I can't find the link but search briggs and Stratton accessories and there will be a full section of exhaust in there.
Depending upon your engine model/type/code B&S pn 691502 may work, but you will have to weld/braze an elbow onto it to reach your muffler. Richards Relics sells a similar pipe with a welded elbow. Again you will need the correct flex pipe to reach the muffler. He also sells flex pipe, but it is not as flexible as the OEM pipe that came from MAX. Depending upon the muffler that you have you may have to do some fitting to get it all to work. I needed the flexpipe and muffler for my '96 MAX and ended up buying the complete exhaust from Richards Relics and it worked great. Here are photos before I put the clamps on
