It can as the Voltage will leak through and lessen the spark out put at the plug.
But this will happen and Low rpm also. when are you seeing the miss ?
Ok that helps ! Is it a spark miss like flipping the switch or Fuel miss like Leans out and starves one bank ?
You can look at the plugs also. If thy are White and clean it is Fuel. Black and sooty then Spark.
Right on, pulled plug on that cylinder, was black and sooty, front plug looked good, this engine only has about 6 hrs on it. Just put new coil on, off to test drive...
