Just put a new comet 780 driven clutch in last year and its already missing a slider button. Does anyone know of a better style of button? I’ve had this happen on my other machine also, but it was an older worn clutch.
Hey Trevor, I'd call Roy at QDS and tell him what's going on.
https://www.yelp.com/biz/quality-drive-systems-alhambra
For whatever reason my driven also dumped a button a few different times (one time two were missing). I couldn't afford to buy a different type of clutch so I ended up installing a new origina-style instead.
I now keep it lubed more often then I used to. So far so good. A new season coming up, we'll see.
Well I finally got around to pulling the driven comet 780. It’s on a Max IV so not so easy to get at. Does anyone know of a different style clutch to replace this. Maybe one with rollers. I’m tired of losing buttons. As I mentioned earlier this clutch was new and lost a button. Otherwise I can try calling Quality drive as Joe mentioned.
My Max IV also has a new driven clutch installed last year (3rd one), with no missing buttons.
A few weeks ago, after a long drive, one was missing. Another one put in, and now, one is missing again! I'm installing three new ones tomorrow.
Any idea what size is the retainer external snap ring holding the clutch together is?
Deffinately need a roller-type clutch.
Lost another slider button on a 780. About 10 hrs on this clutch. I’m told the Comet is the way to go but I can’t keep doing this. There’s got to be a better clutch out there that can accomplish the same thing. I placed a call to Quality Drive as recommended. Left a message. Maybe better luck after Christmas. Anyone else losing buttons? How about you racer guys? Anyone recommend a Comet 780 equivalent?
Anyone figure out the missing buttons? I put a drop of super glue to hold the 3 new ones in and now 2 are cracked!! I have less than 6 hours on these and no hard trails. How bad is it if I run them cracked for a bit? I really dont want to pull this apart again!!!
After losing a few buttons I called Roy at Quality Drive as recommended on here. He said the buttons are supposed to be locktited in with green locktite. Mine were not. I haven’t tried this yet but certainly will next time it happens.
