Irregular chain tension
+ Reply to Thread
Results 1 to 7 of 7
Thread: Irregular chain tension
  1. #1
    Join Date
    Apr 2009
    Location
    two egg florida
    Posts
    46
    Hey what would cause t-20 chain tension to be tight then loosen as you turn it? I removed chains to investigate but transmission and jackshaft s seem to work normal.
  2. #2
    Join Date
    Sep 2010
    Location
    rhode island
    Posts
    709
    lift machine off ground completely and wiggle tires to check for worn bearings.
  3. #3
    Join Date
    Feb 2013
    Location
    shenendoah valley,va.
    Posts
    2,639
    also check the t 20 trans mounting plates it bolts to in case holes are worn or mount has broken ... j.b.
  4. #4
    Join Date
    Apr 2009
    Location
    two egg florida
    Posts
    46
    Thats a great idea didn’t think of that
  5. #5
    Join Date
    Oct 2007
    Location
    statesville, north carolina
    Posts
    2,604
    Either a bent shaft, sprocket was not centered when it was welded in place, or someone replaced part of a used chain with a new piece (would have 2 master links)
  6. #6
    Join Date
    Apr 2009
    Location
    two egg florida
    Posts
    46
    I have new shafts on both sides old ones were bent. I currently still have the same problem.I think transmission is not aligned straight in frame.I just haven’t had time to work on it lately.
  7. #7
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    I'd pull off the chain in question, have seen many chains with bent or twisted links. Roll axles over after chain removal to check you are in the right spot.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
