6 x 6 23 hp Kohler Power Question
+ Reply to Thread
Results 1 to 7 of 7
Thread: 6 x 6 23 hp Kohler Power Question
  1. #1
    Just got a used 6 x 6 with the 23 hp EFI Kohler engine. The max rpm's that I can get is 3400. The Kohler books specs 23 hp @ 3600 rpm's. I am running rubber tracks.
    Is 3400 normal or should it be reving higher?
  2. #2
    Quote Originally Posted by esimon4 View Post
    I have the same machine.
    Rubber tracks will slow down your top speed but not sure what the top RPMS is on mine.
    Not a speed demon either way.
  3. #3
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    402
    What elevation are you running your machine at? If it is considered high altitusde you can reduce the weight of the primary cluth weight and get those RPMs back.
  4. #4
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Argos are usually set at 4000 unloaded rpm, meaning in neutral, so they can reach 3600 in gear but efi engines sometimes will not reach that due to computer. Under load rpm varies as to load, tracks would be a factor.
  5. #5
    Join Date
    May 2010
    Location
    Fairbanks AK
    Posts
    1,457
    I set max and Argo governors at 4000-4100 with just the belt load. You will have to replace the governor set screw wit longer one to get that speed out of a kohler. It’s the metric bolt that pushes on the governor arm. If it was a box engine it’s set at3400-3600 rpm. Briggs v twins require a different main spring to get those rpm’s.
  6. #6
    Thank you all for the advise. I am in Michigan so elevation is not really a factor. i will rev it in Neutral to see how hi it will go.
  7. #7
    Took it back to the dealer and they fixed the throttle plate. It was only hitting 3100 rpm and now does 3400 with the tracks on. Still haven't rev'd it up in neutral but it really goes now!
    The 3400 in my first post was a typo. Plowed some snow with it and had a ball.
+ Reply to Thread
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
