Keyed axles
+ Reply to Thread
Results 1 to 5 of 5
Thread: Keyed axles
  1. #1
    Keyed axles
    Contemplating axle options for a Hustler build. Have saw a couple of builds that used 1.25 inch keyed axles, Meinfield's comes to mind. Did not see how the wheel hubs were installed. I suppose they probably welded them on, but am wondering if a keyed wheel hub would work since I currently lack a welder?
    Lug
  2. #2
    Join Date
    Feb 2013
    Location
    shenendoah valley,va.
    Posts
    2,633
    lug .. i have 1 1/2 '' axles keyed with keyed hubs on my max 2 . they have had no problems for 2 years . but on my design , i welded the original 1 1/4 '' hub to a 1 1/2 '' keyed shaft coupler. i also put a 1 1/2'' split collar on the axle next to the coupler and welded one half of the collar to the hub , then clamped it down on the axle for some extra '' grip ''. if you have a 1 1/2 '' keyed hub on a keyed axle it should work . if the hub only attaches to the axle with a key and a allen set screw , you may need to drill a hole thru the hub and axle for a tight connection. hope this helps , johnboy va.
  3. #3
    John,
    Just found your build pics for the high boy Max and now know how you are able to run 1.5 axles. How has that set up worked out for you? I am in Alaska and would be using mine in some pretty rough country with marshy areas and stream crossings. After looking at your pictures I had visions of making a 8x8 subframe. Might have to do some photochopping once the snow and mud in the backyard goes away.
    Lug
  4. #4
    Join Date
    Feb 2013
    Location
    Posts
    2,633
    lug...i've run this machine over 2 years with the subframe design and for me it works great . easier to work on the chains and bearings , etc. than down in the tub. easy to keep them clean , oiled and greased . same bearings for all this time . i run # 60 chains with adjustable bearing mounts which eliminates the tensioners. it has added overall weight , but with the 23 h.p. briggs there is plenty of power . i have pretty much worked out every design challenges so if anyone builds one i can give some pointers . the few videos of the build show the basic fabrication procedures. keep in touch.....johnboy va.
  5. #5
    Johnboy va,
    I found your videos of the Mk. II rebuild of you Max. That turned out nice. Are you still running without any chain covers?
    Lug
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
