Hi everyone, I have a Prairie Bobcat (PB) 6x6 amphibious machine with skid steer type steering which I purchased a few years ago that I'm trying to get running again. After replacing the starter on the 17hp Kohler twin cylinder engine it ran well, but I had a problem with one of the drive chains being too loose, which I attempted to tighten without much success at first, but figured it out later.
Another issue is that when accelerating to go up a hill or up loading ramps the governor seems to disengage, and I lose power and I can't make it up the ramp or steep hill. It doesn't seem to be a problem when I get a run at it, but if I try to ease up the loading ramps it starts going up and then about half way up the ramps I lose acceleration and the throw-out pulley (like the drive belt pulley on a snowmobile) or whatever it is called widens up and the belt becomes disengaged and the machine looses forward movement. Any information on how to adjust the governor or whatever it is that needs adjusting will be a great help and much appreciated.
I also have a question about the steering brake bands; the brake bands on the PB are narrow bands that compress around the outer circumference of the drum or rotor instead of compressing the rotor between two pads like found on cars or motorcycles. Is it possible to change this braking/steering system to something like a motorcycle braking system or should I just stick with the existing system, which doesn’t seem like it would work as well and would be harder if not impossible to find parts for? Should I consider operating the braking system with hydraulics instead of using existing linkage system?
I have a few other questions but will try to address them one or two at a time in future posts.
Thanks
Thanks
