Hang in there guys... soon enough we will start seeing the 6x6 events grow again.. It seems like attendance really dwindled after RI stopped producing MAX.. Once we re-launch the MAX 2 this fall, we will be working hard to promote the community as well as sponsor rides!
Busco Beach April 2023
scott and john and j shade .....only once and his friend can go the weekend of the 31 st , april 1 st. mike fen is going then also . i can go then if it would work for you guys instead of the 21 st. if not , mike and i and you all will stay with the 2i st weekend . let us know . thanks , jboy
great riding and great mud ...johnboy , mfenmore,onlyonce keith and his friend dave . with a small group we rode alot of hrs. and each time getting stuck ( was alot ) there was someone right there to pull you out . a few breakdowns , flats , etc . took on water in one hole with the max 2 highboy ...but was saved by a quick strap hookup . pulled the plugs , alittle water and off we went . it took 2 machines to pull out one very stuck lifted side by side ..and 2 machines again to pull out a fully submerged side by side on sat. part of the fun ! johnboy va
Glad you guys had a good time, hopefully the 2nd part is goodOriginally posted by john swenson View Postgreat riding and great mud ...johnboy , mfenmore,onlyonce keith and his friend dave . with a small group we rode alot of hrs. and each time getting stuck ( was alot ) there was someone right there to pull you out . a few breakdowns , flats , etc . took on water in one hole with the max 2 highboy ...but was saved by a quick strap hookup . pulled the plugs , alittle water and off we went . it took 2 machines to pull out one very stuck lifted side by side ..and 2 machines again to pull out a fully submerged side by side on sat. part of the fun ! johnboy vasigpic
