I just got a Terra Tiger and was wondering how does a person install a new drive belt on one of these? Looks very labor intensive.
Toyman's AATV Toys;
Max IV
Project Muscateer (trans. rebuild)
Previously owned AATVs; Terra Tiger, pair of MaxIIs and Attex 450 Tomahawk, Hustler
it is a bit of a project, you have to remove the jackshaft. while you are doing it, put 2 belts on there. tie one off with sip ties the the left side steering control. that way next time you need to change belts, you just cut the old one and pull it out and slide the new one into position. if you pm me your email i can send you a pdf of the owners, and service manuals
enjoy your new tiger!
Not as hard as it looks. Remove motor chain cover and hood scoop and take belt off engine clutch. Loosen lock collars on brgs. Unhook steering rods, chains and brake cable. Now remove 3 bolts from brg. flanges and remove outer plate on outside body, each side. Now tap the brgs inward on each side of shaft. Also remove 2 bolts from each side holding steering pivot & brake units. Then move shaft assembly it to one side, so one end lifts out and then remove out rear or top. We have left motor in also, just a little harder working around it. Any questions let us know.
racerone3 could i get a pdf of the manuals also my email is bone65200214733@yahoo.com im a new terra owner also thans steve nalbone
Thanks for the info. I'd appreciate your offer of the pdf. toyman_1957@yahoo.com
Toyman's AATV Toys;
Max IV
