Came with NOS uncut top. Original frame was junk. Came with newer good frame. Reinforced the bearing mounting areas. Using Argo HD bearings with custom 3" UHMW bearing extensions/synthetic bearings. Made chain adjusters. New solid axles and sprockets. Split the shifter. Picking up 670 predator this weekend. Adding mild cam, heavier valve springs, custom exhaust in stock location, and intake. LED headlights and taillights.
Still have original 3 bolt axle if someone can use them along with 3 to 5 converters.
Looking for stock roll bar to make roll bar fab a little easier. Plan is to put it to the test at Busco.
Basically all mechanical parts are new.
