I bought a 2007 Max IV and I am adding some options and wanted to get some real world info. I see that RI states the load capacity of a stock max IV is 500lbs in the water less installed options. My use is to drive the Max to my boat,with my family, about 100 yards off shore (because the lake is very shallow sand). I have to cross an area that is deep enough for the Max to float and I want to make sure it will do so safely with the options I have picked.
It is a stock 2007 max IV with the 18HP vanguard and 26" Goodyear tires. I have added a 3000lb winch and winch mounting rack from country ATV. I am considering added the roll cage and seat belts but I want to make sure it will still swim OK with 450LBS of load (the combined weight of my family).
In looking for info I see that my options add the following amount of weight"
26" tires= 114lbs over the stock Max IV tires
Winch Mount= 35lbs
Winch= 30lbs
Roll Cage and Seat Belts= 85lbs
It also lists the following as additonal weight options:
O-Ring Chain= 8lbs
Front and rear Skid Plates= 13lbs
Heavy Duty Solid Axles= 29lbs
So that totals 314lbs in accessories. 500lbs capacity - 314lbs in accessories only leaves 186lbs capacity per the owners manual. So per RI, I could only ride in the water by myself. I would hope that the 26 inch tires would add some buoyancy but I feel like I am pretty far away from the capacity I am looking for...should I not add the roll cage? How conservative is the 500lb limit set by RI?
Any real world knowledge would be greatly appreciated. I am 264lbs away from what RI says is safe in the water...
